// Plotclock
// cc - by
Johannes Heberlein 2014
// v 1.01
// thingiverse.com/joo wiki.fablab-nuernberg.de
// units: mm; microseconds; radians
// origin:
bottom left of drawing surface
// time
library see http://playground.arduino.cc/Code/time
// delete or mark the next line as comment when done with calibration
#define CALIBRATION
// When in calibration mode, adjust the following factor until the servos move exactly 90 degrees
#define SERVOFAKTOR 620
// Zero-position of left and right servo
// When
in calibration mode, adjust the NULL-values so that the servo arms are at all times parallel
// either to the X or Y axis
#define SERVOLEFTNULL
1900
#define SERVORIGHTNULL 984
#define SERVOPINLIFT 2
#define SERVOPINLEFT 3
#define SERVOPINRIGHT 4
// lift positions of lifting servo
#define LIFT0 1080 // on drawing surface
#define LIFT1 925 // between numbers
#define LIFT2 725 // going towards sweeper
// speed of liftimg arm, higher is slower
#define LIFTSPEED 1500
length of arms
#define L1 35
#define L2 55.1
#define L3 13.2
// origin points of left and
right servo
#define O1X 22
#define O1Y -25
#define O2X 47
#define O2Y -25
#include <Time.h>
// see http://playground.arduino.cc/Code/time
#include <Servo.h>
int servoLift = 1500;
Servo servo1; //
Servo servo2; //
Servo servo3; //
volatile double lastX = 75;
volatile double lastY = 47.5;
int last_min = 0;
void setup()
// Set current time only the first to values, hh,mm are needed
setTime(19,38,0,0,0,0);
drawTo(75.2, 47);
lift(0);
servo1.attach
(SERVOPINLIFT); // lifting servo
servo2.attach(SERVOPINLEFT); // left servo
servo3.attach(SERVOPINRIGHT); // right servo
delay(1000);
void loop()
#ifdef CALIBRATION
// Servohorns will have 90° between movements, parallel to x and y axis
drawTo(-3, 29.2);
delay(500);
drawTo(74.1, 28);
delay(500);
#else
int i = 0;
if (last_min != minute()) {
if (!servo1.attached()) servo1.attach(SERVOPINLIFT);
if (!servo2.attached()) servo2.attach(SERVOPINLEFT);
if (!servo3.attached()) servo3.attach(SERVOPINRIGHT);
lift(0);
hour();
while
((i+1)*10 <= hour())
i++;
number(3, 3, 111, 1);
number(5, 25, i, 0.9);
number(19, 25, (hour()-i*10), 0.9);
number(28, 25, 11, 0.9);
i=0;
while
((i+1)*10 <= minute())
i++;
number(34, 25, i, 0.9);
number(48, 25, (minute()-i*10), 0.9);
lift(2);
drawTo(74.2, 47.5);
lift(1);
last_min
= minute();
servo1.detach();
servo2.detach();
servo3.detach
#endif
// Writing numeral with
bx by being the bottom left originpoint. Scale 1 equals a 20 mm high font.
// The structure follows this principle: move to first startpoint of the numeral, lift down, draw numeral, lift
up
void number(float bx, float by, int num, float scale) {
switch (num) {
case
0:
drawTo
(bx + 12 * scale, by + 6 * scale);
lift(0);
bogenGZS
(bx + 7 * scale, by + 10 * scale, 10 * scale, -0.8, 6.7, 0.5);
lift(1);
break;
case 1:
drawTo
(bx + 3 * scale, by + 15 * scale);
lift(0);
drawTo
(bx + 10 * scale, by + 20 * scale);
drawTo(bx
+ 10 * scale, by + 0 * scale);
lift(1);
break;
case 2:
drawTo
(bx + 2 * scale, by + 12 * scale);
lift(0);
bogenUZS
(bx + 8 * scale, by + 14 * scale, 6 * scale, 3, -0.8, 1);
drawTo(bx
+ 1 * scale, by + 0 * scale);
drawTo
(bx + 12 * scale, by + 0 * scale);
lift(1);
break;
case 3:
drawTo(bx + 2 * scale, by + 17 * scale);
lift(0);
bogenUZS(bx + 5 * scale, by + 15 * scale, 5 * scale, 3, -2, 1);
bogenUZS(bx + 5 * scale, by + 5 * scale, 5 * scale, 1.57, -3, 1);
lift(1);
break;
case 4:
drawTo(bx
lift(0);
drawTo(bx + 10 * scale, by + 20 * scale);
drawTo(bx
+ 2 * scale, by + 6 * scale);
drawTo
lift(1);
break;
case 5:
drawTo(bx + 2 * scale, by + 5 * scale);
lift(0);
bogenGZS(bx + 5 * scale, by + 6 * scale, 6 * scale, -2.5, 2, 1);
drawTo(bx + 5 * scale, by + 20 * scale);
drawTo
(bx + 12 * scale, by + 20 * scale);
lift(1);
break;
case 6:
drawTo(bx + 2 * scale, by + 10 * scale);
lift(0);
bogenUZS(bx + 7 * scale, by + 6 * scale, 6 * scale, 2, -4.4, 1);
drawTo(bx + 11 * scale, by + 20 * scale);
lift(1);
break;
case 7:
drawTo
(bx + 2 * scale, by + 20 * scale);
lift(0);
drawTo
drawTo(bx
+ 2 * scale, by + 0);
lift(1);
break;
case 8:
drawTo(bx + 5 * scale, by + 10 * scale);
lift(0);
bogenUZS(bx + 5 * scale, by + 15 * scale, 5 * scale, 4.7, -1.6, 1);
bogenGZS(bx + 5 * scale, by + 5 * scale, 5 * scale, -4.7, 2, 1);
lift(1);
break;
case 9:
drawTo(bx + 9 * scale, by + 11 * scale);
lift(0);
bogenUZS(bx + 7 * scale, by + 15 * scale, 5 * scale, 4, -0.5, 1);
drawTo(bx + 5 * scale, by + 0);
lift(1);
break;
case
111:
lift(0);
drawTo(70, 46);
drawTo(65, 43);
drawTo(65, 49);
drawTo
(5, 49);
drawTo(5, 45);
drawTo(65, 45);
drawTo
(65, 40);
drawTo(5, 40);
drawTo(5, 35);
drawTo(65, 35);
drawTo
(65, 30);
drawTo(5, 30);
drawTo(5, 25);
drawTo(65, 25);
drawTo
(65, 20);
drawTo(5, 20);
drawTo(60, 44);
drawTo(75.2, 47);
lift(2);
break;
case
11:
drawTo
(bx + 5 * scale, by + 15 * scale);
lift(0);
bogenGZS
(bx + 5 * scale, by + 15 * scale, 0.1 * scale, 1, -1, 1);
lift(1);
drawTo
(bx + 5 * scale, by + 5 * scale);
lift(0);
bogenGZS
(bx + 5 * scale, by + 5 * scale, 0.1 * scale, 1, -1, 1);
lift(1);
break;
void lift(char lift) {
switch (lift) {
// room to optimize !
case 0: //850
if (servoLift >= LIFT0)
while
servoLift--;
servo1.writeMicroseconds(servoLift);
delayMicroseconds(LIFTSPEED);
else {
while (servoLift
<= LIFT0) {
servoLift++;
break;
case 1: //150
if (servoLift >= LIFT1) {
while (servoLift
>= LIFT1) {
servoLift--;
else {
while (servoLift <= LIFT1) {
servoLift++;
break;
case 2:
if (servoLift
>= LIFT2) {
while (servoLift
>= LIFT2) {
servoLift--;
else {
while (servoLift
<= LIFT2) {
servoLift++;
break;
void bogenUZS(float bx,
float by, float radius, int start, int ende, float sqee) {
float inkr = -0.05;
float count = 0;
do {
drawTo(sqee * radius * cos(start + count) + bx,
radius
* sin(start + count) + by);
count += inkr;
while ((start + count) > ende);
void bogenGZS(float bx, float by, float radius, int start, int ende, float sqee) {
float inkr = 0.05;
float count = 0;
do
drawTo
radius * sin
(start + count)
+ by);
count += inkr;
while ((start + count) <= ende);
void drawTo(double pX, double pY) {
double dx, dy, c;
int i;
// dx dy of new point
dx = pX -
lastX;
dy
= pY - lastY;
//path lenght in mm, times 4 equals 4 steps per
mm
c = floor(4 * sqrt(dx * dx + dy * dy));
if (c < 1) c = 1;
for (i = 0; i <= c; i++) {
// draw line point by point
set_XY(lastX
+ (i * dx /
c), lastY + (i * dy / c));
lastX = pX;
lastY = pY;
double return_angle(double a, double b, double c) {
// cosine rule for angle between c and a
return acos((a
* a + c * c - b * b) / (2 * a * c));
void set_XY(double Tx, double Ty)
delay(1);
double dx, dy, c, a1, a2, Hx, Hy;
// calculate triangle between pen, servoLeft and arm
joint
// cartesian dx/dy
dx = Tx - O1X;
dy = Ty - O1Y;
// polar lemgth (c) and angle (a1)
c = sqrt(dx * dx + dy * dy); //
a1 = atan2(dy, dx); //
a2 = return_angle(L1, L2, c);
servo2.writeMicroseconds(floor(((a2 + a1 - M_PI) * SERVOFAKTOR) + SERVOLEFTNULL));
// calculate joinr arm point for triangle of the right servo arm
a2 = return_angle
(L2, L1, c);
Hx = Tx + L3 * cos((a1 - a2 + 0.621) + M_PI); //36,5°
Hy = Ty + L3 * sin((a1 - a2 + 0.621) + M_PI);
// calculate
triangle between pen joint, servoRight and arm joint
dx
= Hx - O2X;
dy = Hy - O2Y;
a1 = atan2
(dy, dx);
a2 = return_angle
(L1, (L2 -
L3), c);
servo3.writeMicroseconds(floor(((a1 - a2) * SERVOFAKTOR) + SERVORIGHTNULL));
