KLM ELECTRONICS, INC.
LINEAR VHF AMPLIFIERS
CLASS "AB" FM/CW/SSB/AMThis series of amplifiers is designed for 143 to 149 Mhz 2 meter band operation. The designs use the latest in micro-stripline techniques and highest quality state of the art transistors. Relay switching is automatic RF sensing. These units do not require any tuning. The boardband design offers the ultimate in flat input VSWR, 1.4:1 or less, and produces rated power output or better across the entire two meter band. This amplifier can be used for AM or SSB operation as well as FM and CW.
The front panel switch on all models switches the amplifier in or out. Withthe switch "in", the 13.5 VDC is supplied to the RF sensing and relay circuit inside the amplifier, however, the unit will not draw any current until the transceiver or transmitter is keyed and RF is applied to the amplifier. At this point an audible click of the relay can be heard and the LED light on the front panel will light. The amplifier will now amplify the RF applied. In the "out" position, the amplifier will bypass the RF through the amplifier.
Forced DC keying can be used by applying + 9 to +15 VDC through a 10k resistor to the base of the MPSA 13 relay driver.
TYPICAL SPECIFICATIONS FOR ALL MODELS
IMPEDANCE: 50 ohms input and output
SUPPLY VOLTAGE: 13.5 VDC (usable from +11 to +14.5 VDC)
INPUT VSWR: 1.4:1 144-148 MHz
DUTY CYCLE: CAS (Intermittant Commerical Amateur Service)
RF CONNECTORS: SO239
MODEL NUMBER
RF POWER INPUT (watts)
USUABLE PWR. INP. (watts)
NOM. PWR. OUTPUT (watts)
NOM. CUR. (amps)
SIZE
FUSE 3AG SIZE (amps)
PA 10-160BL
10
5-15
160
22
6.5x10x2
30
PA 2-70BL
1-4
10
6.5x7.5x2
15
PA 10-80BL
10
5-15
80
10
6.5x7.5x2
15
PA 10-40BL
10
5-15
40
5
6.5x5x2
71/2
PA 10-70BL
10
5-15
8
6.5x7.5x2
10
PA 10-140BL
10
5-15
140
18
6.5x10x2
25
PA 30-140BL
30
15-45
140
15
6.5x10x2
20
PA10-70BL/PA10-80BL
C2,3,4
68 pf
Underwood
C5.6
200 pf
Underwood
C8,9,16,17,22
.001 MFD
disc
C7.14
1/35 VDC TANT
C10.11
100 pf
Underwood
C2.12
47 pf
Undeiwood
C1,13,20,21
750 pf
DM15
C19
5pf
disc
C23
25/15 VDC Eletrolytic
C18
47 MFD
63 VDC
C15
1000pf
Feed Thru Allen Bradley
D3,4
1N914
R6
22k
1/4 Watt
R5
560 OHM
1/2 Watt
RFC1.3.5
.15uH
Q1
MRF245
Motorola
Q2
MPSA13
Motorola
R7
560 OHM
1/4 Watt
R2
100 OHM
Pot
R3
3 OHM
1/4 Watt
R4
50 OHM
5 Watt
S1
Alco
SPDT
LED
MV5053
R1
15 OHM
1/2 Watt
RFC2
5T#16
1/4" Dla. x 1/2" Ig.
RY1
Relay 1355/1365
D2,1
1N4003 Diodes
F1
Fuse
15A
RFC4
4.7uH
PA30-140BL
C3,4,5,11,13
68 pf
Underwood
C6,7,12,14,10,17
200 pf
Underwood
C9,16,24,23,29
.001 MFD
disc
C8,15,19
1/35 VDC TANT
C22
47 pf
Underwood
C1,21,27,28
750 pf
DM15
C26
5pf
disc
C20
25 MFD
16 VDC
R7
22k
1/4 Watt
RFC2,3,1,5
.15uH
RFC6
4.7uH
Q1,2
MRF245
Motorola
Q3
MPSA13
Motorola
RY1
Relay #1355/1365
Guardian
D2,3
1N914
D1,4
1N4003
R8
560 OHM
1/4 Watt
R6
560 OHM
1/2 Watt
R3
100 OHM
Pot
R4
3 OHM
1/4 Watt
R5
50 OHM
5 Watt
R1,2
15 OHM
1/2 Watt
S1
Alco
SPDT
LED
MV5053
C30
33 pf
Underwood
RFC4
5T#16
1/4" Dia.
C25
47/63V
Electrolytic
C18,2
F1
Fuse
15A
PA10-160BL
C36
47 MFD
63 VDC
C13,14,15,21,23
68 pf
Underwood
C16,17,22,20, 24,27
200 pf
Underwood
C18,25,34,35,40
.001 MFD
disc
C19,26,30,10
1/35 VDC TANT
C2,6,28
47 pf
Underwood
D1,7,32,38,39
750 pf
DM15
D37 C31
5pf 25 MFD
disc 25 VDC
D8,9,29,11,12
470 pf
Allen Bradley
D5
100 pf
Underwood
R12
560 OHM
1/4 Watt
R10
560 OHM
1/2 Watt
B1
15 OHM
1 Watt
D4,5
1N914
D1.2.3
1N4003"
02,3
MBF 245
Motorola
Q4
MPSA13
Motorola
Q1
2N6084
Motorola
BFC3,4,5
.15uH
Choke
RFC8
4.7uH
Choke
B11
22k
1/4 Watt
B3,6
100 OHM
Pot
B2,5
3 OHM
1/4 Watt
B4,7
50 OHM
5 Watt
BFC1,2,6
5T#16
1/4" dia.
BY1
Belay 1355/1365
F1
Fuse 25A
LED
LED and Mount
MV5053
S1
Alco SPDT
PA10-40BL
C1,9,17,18
750 pf
DM15
C2,8
68 pf
Underwood J101
C3,4,7
200 pf
Underwood J101
C5
.01
disc
C6.11
1 MFD
35 VDC TANT
C13,19,10
.001 MFD
disc
RFC1,4,2
.15uH
RFC5
4.7 nH
C16
5pf
disc
Q1
B40-12
CTC/2N6084
Q2
MPSA13
Motorola
B1
15 OHM
1/2 Watl
B6
22k OHM
1/4 Watt
R5
560 OHM
1/2 Watt
R7
1000 OHM
1/4 Watt
R2
100 OHM
Pot
R3
3 OHM
1/4 Watt
R4
50 OHM
5 Watt
LED
MV5053
S1
Alco
SPDT
C15
47/63
Electrolytic
D3,4
1N914
RFC3
5T#16
1/4" Dia.
RY1
Relay 1355/1365
D4,5
1N4148 or 1N914
D1,2
1N4003 Diode
F1
Fuse
7 1/2A
C12
Allen Bradley
PA 2-70BL
C2.14.17
100 pf
Underwood
C6.15.29
47pf
Underwood
C10.11
200 pf
Underwood
C8.9
66 pf
Underwood
C1,5,16
750 pf
DM15
C3,12,21,22,27,28
.001 MFD
disc
C13,4,18
1 MFD
35 VDC TANT
C24
5pf
disc
C23
47/63V
Electrolytic
R11
560 OHM
1/4 Watl
R10
22k OHM
1/4 Watt
R9
560 OHM
1/2 Watl
R8
15 OHM
1/2 Watt
RFC3,5,6
.15uH
Choke
Q3
MPSA13
Darlington
RFC7
4.7uH
Choke
C7
22 MFD
16 VDC
D4,5
1N914
Q1
B12-12
Q2
MRF245
R2,6
100 OHM
Pot
R3,5
50 OHM
5 Watt
R4,7
3 OHM
LED
MV5053
S1
Alco
SPDT
RFC1,2
5T#16
1/4" Dia.
RY1
Relay 1355/1365
RFC4
7T#16
1/4" Dia.
D1,2,3
IN4003 Diodes
C19,20
F1
Fuse
15A
R1
15 OHM
1 Watt
INSTALLATION INSTRUCTIONS:
Connect the positive supply voltage to the red fused lead Connect the gnd lead to the negative or ground side of the power source Number 12 AWG wire or larger is recommended if the supply leads need to be lengthened Connect the amphfer between the transmitter or transceiver and the antenna RG-8A/U or equivalent coax is recommended for the connection between the amplifier and the antenna The amplifier may be mounted in any position
INSTALLATION HINTS:
1 Check all coax cables for proper impedance (50 ohms) and freedom from shorts and/or opens
2 Although the maximum input SWR to the amplifier is 1 4 1, some transceivers may still be unable to produce power into the amplifier If this occurs, try a different length of coax between the transceiver and the amplifier One half wave multiples is probably the best choice (Belden foam 8214 31 5 inches RG-8LJ 26 75 inches )
3 If the amplifier switching is intermittent or if the relay buzzes when keyed, check the following a Inadequate drive power from the transceiver
b High antenna SWR (Try adding another 1A wave to the feed line )
c RF getting back into the transceiver caused by close antenna proximity, poor mic shielding, etc
4 If the amphfer appears to produce low power out, check the following
a A watt meter between the amplifier and the transceiver will check the drive level
b Measure the voltage during amplifier operation as close to the amplifier as possible Voltage for spec output is 13 5 VDC c Even the best watt meters have an accuracy tolerance and they can be fooled if harmonic or parasitic energy is present Check the power at least two positions in the input and output line of the> amplifier, there should be no significant change in power
5 The amplifier when installed should draw no current (less than 10 MA)
