The DK7ZB-Reflector-Hentenna
Descriptions for 144-MHz- , 70 MHz- and 50-MHz-Reflector-Hentennas below!
The original Hentenna as a special kind of a single loop was described first in the 1970ies by Japanese Hams, an English article by JF6DEA/KE1EO about the Antenna ("The Hentenna – The Japanese 'Miracle' Wire")  was in the QST 1982 and in the ARRL-Antenna- Compendium, Vol. 5. The basic function of the  Hentenna structure is the 1,50-λ-Extended-Quad. This antenna with the figure of an "Oblong" has a gain of 3,6 dBd, but a feedpoint impedance of 73 + j 470 Ω.
The Hentenna has nearly the same gain, but a clever feeding with an impedance at XX of 50-70  +/- j 0 Ω .
The parts have the following lengths:
W - 1, 6, 7: 0,15 λ
S - 2, 4: 0,1 λ
H - (3+2), (5+4): 0,5 λ
The data of the Hentenna-Loop:
Gain 3,05 dBd
3-dB-Azimuth-angle 88,2°, 3-dB-Elevation-angle 69,5°
Введите частоту : (МГц)
Длина элементов W (λ/6) (мм)
Длина элементов S (λ/10) (мм)
Длина элементов H (λ/2) (мм)
On-Line calculator from RA3TOX http://rfanat.ru
Left: Azimuth-plot
Right: Elevation plot
The 144-MHz-Reflector- Hentenna by DK7ZB
With two reflector elements the Hentenna can be changed from a bidirectional antenna to an interesting directional antenna.
50-Ω-Impedance, fed with a 50-Ω-coax-choke (look for the pictures). A vertical metallic support through the antenna system has no influence to the feedpoint impedance and the resonant frequency!
Gain 7 dBd, F/B 15 dB
Dimensions for a 2-m-Reflector-Hentenna wit 10-mm- and 12-mm-elements
Segments Lengths 12 mm Lengths 10 mm
1, 6, 7 (hor) 314 mm 314 mm
3,5 (ver) 824 mm 822 mm
2,4 (ver) 219 mm 218 mm
8,9 (Ref) 1006 mm 1003 mm
Dist. Rad-Ref 320 mm 325 m
The mechanical details of the construction. The loop edges and the connections are made of copper-fittings for 10-mm-tubes
The 50-MHz-Reflector-Hentenna by DK7ZB
With two reflector elements the Hentenna can be changed from a bidirectional antenna to an interesting directional DX-antenna.
The data of the Hentenna with two reflectors by DK7ZB:
Gain 7,05 dBd, F/B 12,5 dB
Impedance 50 +/- j 0 Ω
3-dB-Azimuth-angle 71,4°, 3-dB-Elevation-angle 59°
The vertical pattern is a little bit asymmetric with a 3° upward lobe (see down).
Segments
Length
1, 6, 7 (hor)
900 mm
3, 5 (ver)
2343 mm
2, 4 (ver)
625 mm
8, 9 (Ref)
2900 mm
Distance Ref-Loop 975 mm, all elements 12 mm diameter
The 70-MHz-Reflector-Hentenna by DK7ZB
Pattern and gain are the same as with the 50-MHz-antenna, dimensions for 12-mm-elements in the table below
Home Page of DK7ZBwww.qsl.net/dk7zb/Quadlong/Hentenna.htm
